NSW guys also love cock as a daily
with visibility equivalent to this
and $5000 for something like a replacement or repair front bumper, i'd say its not an ideal daily IMO...
he has a 400+kw skyline for a weekender, i dont think many f**ks are given, its reliable and fun to drive.
I'd like to point out that I personally have NOTHING against the lotus or using it on the roads as a daily...
I merely took the opportunity to point out the fact that most N.S.W. men enjoy the penis
cheeseburger society burgers look good... would def try.
also went to Fat Bob's t'other day and it was pretty good. long wait and expensive but very good.
still prefer to eat 2 x huxtaburgers and chips for the same price as 1 fat bobs though
I beleive dezzman is of a similar opinion
  • Like 1
I tend to make my own burgers most of the time cos I am boss and i like to drink beer at home
thus joy of burger trucks, grab burger, home in a couple minutes, drink beer.
I occasionally get beatbox kitchen when in port melb as can be home in under 5 min.
or Mr Burger when in Yarraville and home sooner.
Invite next time please :P
Mr Burger have a shop on Chaps now as well. Have been meaning to go there.
burgers at home are just as quick and easy if you are prepared.
I buy all my fresh fruit, veggies and such from the market for the week and then get 2 weeks worth of meat from Tasman.
I always buy a bulk pack of premium mince and prep it for burgers.
I also go to Breadtop and buy 4-5 packets of savory rolls at a time and throw the packs in the freezer.
These are the absolute last word in awesome home burger buns and aren't even a little bit effected by the freezing process, just in the bags they already come in. they are small though, so you need to eat 2-4 each
The good thing about Tasman is that the way they pack their mince is directly from the mincer to the pack, so all the meat strands (and hence protien strands) are aligned and when not mixed up make unbeleiveable burger patties.
I get the mince and lay the strands (all facing the same way) on gladwrap to be a little bigger than the size of the buns and roll the shit up nice and tight to get a perfect pattie shape but with all the strands facing the same way. using a LOT of gladwrap.... a LOT
make a few logs and throw them all in the freezer too.
this process take like 5 mins at most.
To cook them, just remove from the freezer and once thawed enough cut into thick pattie slices (with the gladwrap still on and using a SHARP knife) and lay on bench to thaw properly and at room temp (doesn't take long after sliced)
heat a thick pan or the BBQ until red hot, salt the meat heavily with sea salt flakes and cook (still with the gladwrap on)
as soon as the gladwrap gets near the heat it shrinks and doesn't actually hit the heat and melt, cook one side, turn over and remove the gladwrap.
cook until still medium... and you have the most awesome burger pattie imaginable
Then I always ensure I have a pack of bega super slices in the fridge at all times (epic American burger style cheese) and can have burgers with minimal notice at any time.
the rest I change up based on what I feel like...
  • Like 1
fark you just made my mouth water you kent.
and ive got a spinach and ricotta pastie for lunch. vegetarian shite.
+1 for tasman meats.
+1 for market food but fark I hate going to dandenong market most of the time. parking + fighting through the crowds isnt fun. Shame south melbourne isnt as close as it used to be :( good boutique beers there too. Cant find Metal Head Porter anywhere!
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
