had to laugh last night.
Went to get some fuel, (saw price did not laugh) bunch of Bros there standing round the mates new A5 4door coupy things all in their muscle shirts and shit, (turned out to be a smart move)
trying to impress the ladies, showing how swag they were.
Guy finishes putting in fuel, pays. about to leave...genius who jsut bought his car goes super pale..bros help him push car to the side of the servo...
guessing the TDI badge on the back and the fact the petrol station only stocks Unleaded might have had something to do with it tho.
:rofl:
realized prior to starting. else with the amount of fuel in the line I would have expected them to make the realization further down the street not still in the servo.
so won;t be bad a siphon and a refill and should be good to go again, bet he never makes that mistake again tho.....
you say that, the bosses dads car has had it 3 times. he did it, and his wife did it twice and it was driven all 3 times.
excited for new catch can. Cusco and greddy are too chunky plus no drain. plenty on the american market, but dubious build quality and when designed for V8s its a bit hard to judge.
It ain't all good, and that's the truth...
Thangs ain't goin like you think they should...
I don't care about what you think you see
The thangs you want to know when you look at me
God knows I done been there and paid my dues
I can't change how you feel, cause it's all, on you-whoahhha-ohhhhh
Chorus
[Chaka Khan ad libs to end]
lol thats awesome!
picked up ps4 yay - had to come home and let electrician in, so I still need to go get a game after.. was thinking the new need for speed
lol thats awesome!
As for games, you're spoiled for choice since you have access to many games. Hell, you can browse while you're getting paid :P
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
