One of the boys from WL had a good idea...get a couple locals to leave shitboxes scattered in strategic locations at the carpark during the day.
LOL
but are there enough r32s to make the entire carpark awkward?
DOUBLE LOL
Well I saw Pat yesterday and he's shipping his off to Perth on the 27th... Might be able to reroute it with a call to the shipping company.
  • Like 1
Wouldn't want to think about the fuel costs for a roadtrip like that :P
On a related note:
Yesterdays average fuel consumption: 46.7L/100km on BP98
56 Litres used is enough to remind me I need to bring a Jerrycan next time. Had a few "wtf" moments trying to accelerate out of a corner on my last 2 laps :P
  • Like 1
On a related note:
Best time for the day?
1:40
1:38
1:34
untimed
1:33.67
All sessions with passengers and traffic because the cars weren't speed grouped at all
It's slowly getting there :) I need more balls to brake later... was hitting the anchors 50-75m too early on both straights and then rolling in :(
On a related note:
just be carefull if nearly out of juice..that's how I lunched my engine.
fuel starvation and massive detonation.
since when does Aust post deliver on weekends.
sent a Christmas present to WA:
Date/Time
Activity
Location
Sun 22 Dec 2013 11:10
Delivered
MOUNT HAWTHORN WA
Sun 22 Dec 2013 07:35
With Australia Post for delivery today
OSBORNE PARK WA
Sat 21 Dec 2013 09:19
Processed through Australia Post facility
OSBORNE PARK WA
Mon 16 Dec 2013 21:28
Shipping information approved by Australia Post
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
