What is this cool event on the 28th of September or is it super hush hush? I might need to book a loooooooooooong weekend, my 30th on the 27th.
it's something that I need to finalize booking in.
All Melb central/surounds, and will be amazeballs
duct tape....answer to everything
if you need a spare wheel for the weekend I could provide a 245 17? mmmm lightweight
I've got some 17's with 235's or 17's with 255's that aren't on the car right now if you want to borrow a set for the weekend :) It's going to be a great day out
It's all good guys, used duct tape and it seems to have done the trick..... on a serious note, won't have time to fix broken studs before Sat. Thanks fellas.
racing badge...yeah whoever put it there should be shot, these are the std ones much nicer:
http://www.enkei.com/nt03m.shtml
They are standard Enkei badges, from the 90's. I think there's supposed to be japlish parables either side of the lettering but they don't last and end up being rubbed off somewhere through the years.
Nah man I know nothing about 32s only 33s
Doesn't matter what year, all 32R's look the same, why does everyone always seem to instal LH N1 vents goofy though?
No headlight changes or differences at all over the years?
So last night was driving down south rd and a divvy van was sitting at the lights waiting to turn right...
He ripped out of the turning lane without indicating, cutting off a driver and nearly causing an accident, then sat behind me for about 1km.
After this he floored it and cut into the bike/parking lane and overtook me on the left again without indicating, eying me off as he went past at 7000 odd revs. He then proceeded to cut in front of 2 lanes of traffic to avoid hitting a parked car.... once again, no indicator.
would have been close to double the speed limit by the end of it.
When in front of the first car, he chucks his lights on (presumably so as to avoid a complaint from the driver he nearly killed) and cuts off yet another driver in order to make it to a U-Turn spot.
He then turns the lights off and drives off at like 40kph looking at me and smiling like a knob.
wonder if i have an EPA coming? :/
cliffs notes: cop was driving like a fuckbag to prove he could get away with it and i'll probably cop an EPA because of it
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
