ahhh Good work
Cat doesn't normally answer the phone so your lucky lol
Imagine if they did mechanical as well, would be damn impossible to contact them. I leave 4 weeks lead time generally.
Yes that!
In saying that, I understand the business is busy and can be booked out. But implementing a reliable & timely booking system should be easy.
I know a few guys that have since gone elsewhere, not because of his work but due to never getting a reply to trying to make a booking
Haven't been on in like 3 years. What did I miss?
Ayayron wants to plan my funeral, which is nice of him and all, but a bit premature.
What songs would you pick for my funeral? I'd like to know how good your understandings of my tastes would convert to those that probably aren't missing me much, and may not even show up.
That's all I missed in 3 years? Well that's a bit anti-climatic.
Play one of my songs at the funeral so I get royalties, thanks :)
Edited by jezza boii
while i hold nothing against you wanting to make money from your work, if the people at my funeral enjoy it in any way i cant accept it.
It's generic pop rubbish that only 15 year old girls would enjoy.. so they'll hate it. Perfect?
http://youtu.be/A_sY2rjxq6M?t=1m20s
you could be onto something.
while it fits the theme, it could possibly be enjoyed by the people there.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
