ahhh Good work
Cat doesn't normally answer the phone so your lucky lol
Imagine if they did mechanical as well, would be damn impossible to contact them. I leave 4 weeks lead time generally.
Yes that!
In saying that, I understand the business is busy and can be booked out. But implementing a reliable & timely booking system should be easy.
I know a few guys that have since gone elsewhere, not because of his work but due to never getting a reply to trying to make a booking
Haven't been on in like 3 years. What did I miss?
Ayayron wants to plan my funeral, which is nice of him and all, but a bit premature.
What songs would you pick for my funeral? I'd like to know how good your understandings of my tastes would convert to those that probably aren't missing me much, and may not even show up.
That's all I missed in 3 years? Well that's a bit anti-climatic.
Play one of my songs at the funeral so I get royalties, thanks :)
Edited by jezza boii
while i hold nothing against you wanting to make money from your work, if the people at my funeral enjoy it in any way i cant accept it.
It's generic pop rubbish that only 15 year old girls would enjoy.. so they'll hate it. Perfect?
http://youtu.be/A_sY2rjxq6M?t=1m20s
you could be onto something.
while it fits the theme, it could possibly be enjoyed by the people there.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
