Good on ya for being active on your break
Too many students study hard at uni but end up nowhere as they don't have the real life skills to work
Cheers! Indeed. So job. Much need. Good wow.
For sure :P.
Hmm might be in for Show & Shine. Nothing much to show though... And not so shiny atm. Will need a detail. Hmmmmmm.
Water temperatures on my drive home today (constantly moving, no major trafficlight hold ups) were higher than they were after doing multiple hotlaps of Sandown.
Normal: 66-73max
Sandown: 86max
Today: 89c
Normal: 66-73max
Sandown: 86max
Today: 89c
C c c combo breaker
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
