On the topic of who's buying what, GF just bought a lancer ralliart - will be fun to try out the DCT
brand new or a couple years old?
if not brand new/warranty isnt an issue, with a simple retune they will make more power than a stock standard evo 10, you can also flash the gearbox to make it shift better. beeble is the man to talk to http://beebletune.com/
Welcome to the gud lyf
Chuck up a dyno graph Easy E-85
Got no graph at the moment
Got an issue with the car. Its pointing to faulty injectors
So on a trial run with 8 degrees less timing it made 315rwkw @ 4,500rpm before Trent had to back it off
The hooters sauce is actually pretty good, I like to think I make pretty good buffalo wings, a lot of people have had mine and they reckon they havnt had better. So I'm pretty proud, although it's not that hard to make lol
What is it with Lankan's with wings.
Best I've ever had were some my mate who from Sri Lanka did for us
maybe you have same recipe!
Shieeeet still got 3000rpm to go. Massive figures.
Toby pls
Huuuuge numbers brah
Yeah I was only hoping for 320rwkw+
Rev limiter will be set to ~7,800 to 8,000rpm pending so will sure be interesting.
Trent thinks ~400rwkw
Might have to ask for a detune otherwise be too scared to boot it :mellow:
Huge power for RWD Skyline, almost too much lol. But yeah, might as well take advantage of the huge power and get Trent to make it a conservative tune for longevity! Just be careful with third gear...albeit the most fun, they are also the most susceptible to instant gearbox destruction in GTS-T and GTR boxes (especially). What rubber are you running?
Also, I believe you owe me a post-tune ride in your vehicle, Tony.
09
What's better? Faster? Crisper? Gentler?
Picking up this weekend, will be pinching keys quite quickly
Be me
Drop r34 off for transmission work, before 6 week holiday rattle abounds (auto)
Told 1 week
Told no problem
Go on trip, life is awesome for weeks
Return
Car not ready, can't find part over christmas
Ok
Still have daily, eta 1 week
Daily dies 1 day later
Shit. Obtain many lifts
Pick up car on birthday
Pay 2000
Car dies 20 minutes later on highway due to dead fuel pump 5km from barwon prison when you live in eastern suburbs
Hope your day was better!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
