scott that is badass
fast?
I've had it out to 86, but it will do 55-60 on the flat, pedalling my arse off. 35cc 4 stroke, 100k's/L. :)
The 8 inch travel front and rear makes for a plush ride off road, and weighs only 26kg, so I can throw it over a fence easily.
lets race, i choose trail.
Morn... How's the weather over there? Blue skies and 26c here :)
I'm savouring it before the rest of the heat arrives agains
How were your new group of kids?
Hey Simon, pretty nice weather over here, will be 37 degrees today :)
Had the first day of school with the kids yesterday.... I've got an interesting bunch to say the least. One little boy already got moved/yelled out so he will be fun, plus I have 9 students with special needs.... I think I have the most in the school.
Will take a bit of work to get them where I want them behaviour wise, they are also an average/weak group YAY!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
