scott that is badass
fast?
I've had it out to 86, but it will do 55-60 on the flat, pedalling my arse off. 35cc 4 stroke, 100k's/L. :)
The 8 inch travel front and rear makes for a plush ride off road, and weighs only 26kg, so I can throw it over a fence easily.
lets race, i choose trail.
Morn... How's the weather over there? Blue skies and 26c here :)
I'm savouring it before the rest of the heat arrives agains
How were your new group of kids?
Hey Simon, pretty nice weather over here, will be 37 degrees today :)
Had the first day of school with the kids yesterday.... I've got an interesting bunch to say the least. One little boy already got moved/yelled out so he will be fun, plus I have 9 students with special needs.... I think I have the most in the school.
Will take a bit of work to get them where I want them behaviour wise, they are also an average/weak group YAY!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
