still on a stock bottom end? rods not given issues?
yeh unopened engines, they're forged internals standard if I recall correctly
loled @ pic Simon
Edited by UNR33L
Drop car off somewhere for some simple stuff done, wait a week, call to see how its going, get epically disinterested response. Gotta love Melbourne mechanics.
When did they say it was done?
Which workshop?
Say youlll take it else where
ive got into the habit of waiting 1.5-2 weeks before dropping by to check it out. much more awkward when you're there in person. But i havent been to any/many workshops who start work within a few days. I think they just take the car when there is room/when it suits customer, not so much when theyre available to start work.
its best not to be a difficult customer i think... if theyre tied up with another job being a PITA, thats just what happens.
Yeah, I won't be a troublesome customer, I typically am not and pretty chill given experiences in the past. (all nightmarish)
Just annoying if you call a month in advance, deliberately holding off until someone will be available to work on it ;)
Still having issues with your car Greg?
Or it's just a 'maintenance'?
You're doing it all wrong... Backyard mechanics are the go. Bring it down here. :P
It's niggly things that require welding, (sender units for gauges), and wiring etc. Map sensor, Wideband controllers, maybe some dyno time to see the differences in a manifold and gate (assuming these help, typically they should), crap like changing a wheel hub/bearing etc, cam timing, cam gears, valve adjustments.
Simple stuff, just annoying/time consuming, basic but stuff you want to know is done right, because I can't be confident it was right in the past.
I had actually planned to do this initially, at least the welding parts!
But I was told "they can do everything" by the shop, so I said here's a big well detailed list with info, let me know.
If all else fails I will actually park it outside Scotty's and just ask him to let it get stolen.
I'd like to introduce you guys to my future wife, we met on the internet:
:woot::wub:
Booked marked to watch on my lunch break
Haven't heard of her before, but I can see why guys do judging from the preview :P
  • Like 1
That's quite a list...
http://www.theage.com.au/victoria/police-chief-says-luke-battys-father-should-have-been-in-jail-20140214-32pgl.html
5 warrants for that scumbag's arrest, threats of violence towards his family and an AVO from his wife.... yes the poice couldn't manage to go pick him up.
drive past a cop with a modified car and they are more than happy to come and visit
pathetic
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
