still on a stock bottom end? rods not given issues?
yeh unopened engines, they're forged internals standard if I recall correctly
loled @ pic Simon
Edited by UNR33L
Drop car off somewhere for some simple stuff done, wait a week, call to see how its going, get epically disinterested response. Gotta love Melbourne mechanics.
When did they say it was done?
Which workshop?
Say youlll take it else where
ive got into the habit of waiting 1.5-2 weeks before dropping by to check it out. much more awkward when you're there in person. But i havent been to any/many workshops who start work within a few days. I think they just take the car when there is room/when it suits customer, not so much when theyre available to start work.
its best not to be a difficult customer i think... if theyre tied up with another job being a PITA, thats just what happens.
Yeah, I won't be a troublesome customer, I typically am not and pretty chill given experiences in the past. (all nightmarish)
Just annoying if you call a month in advance, deliberately holding off until someone will be available to work on it ;)
Still having issues with your car Greg?
Or it's just a 'maintenance'?
You're doing it all wrong... Backyard mechanics are the go. Bring it down here. :P
It's niggly things that require welding, (sender units for gauges), and wiring etc. Map sensor, Wideband controllers, maybe some dyno time to see the differences in a manifold and gate (assuming these help, typically they should), crap like changing a wheel hub/bearing etc, cam timing, cam gears, valve adjustments.
Simple stuff, just annoying/time consuming, basic but stuff you want to know is done right, because I can't be confident it was right in the past.
I had actually planned to do this initially, at least the welding parts!
But I was told "they can do everything" by the shop, so I said here's a big well detailed list with info, let me know.
If all else fails I will actually park it outside Scotty's and just ask him to let it get stolen.
I'd like to introduce you guys to my future wife, we met on the internet:
:woot::wub:
Booked marked to watch on my lunch break
Haven't heard of her before, but I can see why guys do judging from the preview :P
  • Like 1
That's quite a list...
http://www.theage.com.au/victoria/police-chief-says-luke-battys-father-should-have-been-in-jail-20140214-32pgl.html
5 warrants for that scumbag's arrest, threats of violence towards his family and an AVO from his wife.... yes the poice couldn't manage to go pick him up.
drive past a cop with a modified car and they are more than happy to come and visit
pathetic
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
