Next step, we replace that front bar... :P What boost is it currently running at Rob?
10 on stock turbo.
Frontbar will be done along with bonnet
But next maybe exhaust get rid of those holes or replace the exhaust.
Today was a good day (Friday)
Drove to Grants got lost trying to find a atm, then got lost again trying to navigate the streets where grant lives.
That aside i now have a Apex Hybrid Return Flow intercooler
That looks like a rb20 fmic with a custom pipe to make it fit.
I have the exact same fmic but mine bolted straight up without that extra shiny pipe.
How much it set you back?
Well it was Rob Forbes' ex track car... and he did a hideous backyard respray of the front bar before sale, with what looks to be zero prep to the surface. Paint is chipping off like he didn't even wash it down before painting it.
Rest of the car isn't too bad... mainly just the bonnet and front bar.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
