Next step, we replace that front bar... :P What boost is it currently running at Rob?
10 on stock turbo.
Frontbar will be done along with bonnet
But next maybe exhaust get rid of those holes or replace the exhaust.
Today was a good day (Friday)
Drove to Grants got lost trying to find a atm, then got lost again trying to navigate the streets where grant lives.
That aside i now have a Apex Hybrid Return Flow intercooler
That looks like a rb20 fmic with a custom pipe to make it fit.
I have the exact same fmic but mine bolted straight up without that extra shiny pipe.
How much it set you back?
Well it was Rob Forbes' ex track car... and he did a hideous backyard respray of the front bar before sale, with what looks to be zero prep to the surface. Paint is chipping off like he didn't even wash it down before painting it.
Rest of the car isn't too bad... mainly just the bonnet and front bar.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
