Who does injector cleaning and flow testing for a reasonable price in Melb? Picked up a set of Nismo 555's for $300, think I did pretty well :D
Try injectors online. There in Sth east melb near Sandown i think
I got my injectors flow tested there
Good bunch of blokes down there, I buy all my injectors from them.
I should have an injector test jig set up and running soon, I am setting it up for testing larger injectors as their test jig can only do 1x 2000cc injector at a time. ;)
Anyone have a large volume fuel reg handy they want to sell cheap? That is all I need other than the lines... The 2000hp fuel pump arrived last week so I am ready to make the jig once I get a reg.
out at morwell today and had no idea the smoke was so bad from the coal fire going on. you can see the ash in the air, it's building up on the cars. I don't know how the EPA deems it ok to be outside for extended periods.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
