eh, I haven't come across anything good enough to save lol best i've seen is like bikini shots of a milf in a high position, high enough if I got caught I'd be sacked straight away lol
I really don't snoop though, not that bad if at all - dem ethics. Dunno how deep Simon goes into the rabbit hole :P
Edited by UNR33L
Toby, Titman probs just bemad because he doesn't lift. (Inb4 secretly arnie)
:P
Lol reminds me of fat chicks on FB bitching about "fit girls" being too skinny and should eat more
Edit: Not saying your Fat Titan, just saying theres a generalisation :P
in before tits works for a mob that own a reasonable number of gyms and has free membership.
doesnt even lift bro.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
