Sounds good - I hunger some tempura
Yesterday I got rammed from behind by a guy in a Lancer, then we exchanged numbers :turned:
But on a serious note, he has no insurance and cannot speak very good English (been in the country only ten months). Luckily my insurance said they will wave my excess if I take down his details - also, since I'm not at fault, it will not affect my premium or rating :D
Still a pain in the arse having no car for a while.
disappointing lack of aussie racism in this post.
this is the complete opposite of what usually happens, non?
not at fault does not equal having no claims against your name? (in case of stolen car, accident with someone without insurance etc.)
Who says Alvin doesn't have a big banana? Dat BYC
Simon how does a company monitor employee internet usage. Are they able to monitor everything you do & how much time spend on the internet, apart from browser history?
I was also surprised when they told me this. I checked again to make sure but apparently this is the case; there will be no affect on premium or rating.
I too would like to know this.
It all depends on how the IT systems are set up...
Small business networks are often set up just like a home network is.
Computer -> Router -> Internet
If they have a fancy router, they could install some software on it which tracks requests and links them to users.
Larger business networks are often designed with forensic options in place from day one, or as a happy side effect of proxy server caching.
Computer -> Proxy Server -> Router -> Internet
All traffic passes through the monitoring server, which can be logged against a user if required... Websites visited can be pulled from log files (or automatically made into nice reports listing the sites visited and/or time spend randomly browsing reddit)
Obviously that is just a high level view of some generic setup, there are a lot more in depth monitoring solutions out there.
Just keep in mind that "Incognito Mode" does nothing, all that does is stops records of the visited websites on YOUR pc... Once the request for the site leaves your computer there is nothing to stop it from being intercepted and recorded against you.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
