Brace your ethanol...Melbourne winter is coming
3 minutes to start car this morning
May be seriously considering potentially thinking about possibly switching back to petrol for now
  • Like 1
we all had a lego box as kids.
but shiiiiiit.
have you seen how expensive that shit is nowadays!?
i started asking for star wars lego for xmas.
keep an eye on the kmart sales this stuff gets turned over once a year and Kmart clear theirs for 50-60% off.
last one I got was:
http://shop.lego.com/en-AU/Super-Star-Destroyer-10221
down from 700 to 200
want the death star next, but really hanging for the Ghost busters one coming out this year
Coldest morning since September last year. Some parts reached sub-zero. I think CBD was 4.x degrees; and I think they said Croydon (close enough) was pretty close to zero iirc.
For a brief instant considered delaying e85 tune... realised I'm getting a dual map tune anyway, will just run 98 more often in winter if cold start isn't being ideal.
Speaking of Lego, friend linked me this the other day:
http://www.amazon.com/exec/obidos/ASIN/B00HX14C7Q/ozba0e-20
And yeah, the Death Star in lego always looks impressive.
True dat at expense; yet I saw people had limited edition Millenium Falcons which cost around $600, now going for like $3000 (some guy sold his used set for $2500 lels).
Well yeah, I don't think he is gonna plumb it back for now (re: screamer).
How he is going to fit that into the 5in cat, I do not know. Unless he runs it direct to the body of the cat itself. I believe ARTZ had that done.
But my car cannot be made to 'look very sweet' by the efforts of one man alone.
It will most likely require the efforts of three men, namely scotty, artz, and aaron by the way of his guard roller and general "greg don't do stupid shit" advice.
dont be a top bloke, throw some 225s on a 10 and slam it
Hrmmm I haven't had a cold start issue yet with my e85
We shall see over the coming months though
Only cold start issue I ever had on e85 was due to the fact that for some reason my haltech stopped the fuel pump when cranking (only cranking)
Because...
lemme guess your both running IDs?
Start ya bastard not work?!?
Probably, but it would be started by the time I remove the air filter. I'm mostly daily driving these days and can easily switch back with laptop; 98 unleaded never has these issues.
Just a shame I lose my awesome midrange :(
I run ID's and if it's below 10 degrees my cars a bitch to start.
If the car has been on the trailer over night in winter and I try to start it at the track I have to wait for the temp to get up to about 10 before it will start.
It was tuned on a 35 degree day which probably didn't help.
And I don't mean the can I mean shouting it.
If not try the Marty mcfly trick bang your head on te wheel.
Or try this
http://www.k20a.org/forum/showthread.php?t=85056
Interesting...I know fk all about tuning so I wonder if I can play with a copy of my tune and produce something that doesn't blow up my engine!
ive read a few articles mentioning the same amount.... maybe it could work.
id be taking it back to tuner and retuning in the cold tho....
yeah Trent kept my car overnight and tuned it on cold morning...was actually pretty good....it would fire up and die often...but at least it fired...i know some wont even fire...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
