thank f**k... people are finally starting to buy my spares.
Had things advertised for 6 months with no interest. Sell the spare tyres, old injectors, old manifold, spare parcel shelf and old pistons in a space of 5 days.
speaking of red... waxed my wheels and they turned our real purty. i just find the novelty of clean wheels with new tyres entertaining. like a clean engine block, basically unused.
mmm shiny. poor camera dont do justice.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
