simone. mick says you has universal clutch tool!?!?!?
can i has use of for 10 mins?!
You may. I'll be home in Vermont South after 6pm, but I'm going out at 7:20 if you need it tonight. I can leave it in the letterbox if you want.
oh hai
new car is berry nice
hamish it has 2.3Lkit, 270deg cams, 1k injectors, clutch, flywheel, vipec and usual supporting mods with an evo 9 turbo on it
its tuned for 19psi and i havent driven it on 19psi yet, only 8psi and it flies / pulls awesome in every gear - made 240kw last dyno run
ah was just surprised the setting is even that low, as stock they run much higher?
then again you have a stroker... fun times.
mods collecting dust in my room and garage, need to strap them on to unleash the 2L milk carton fury
Anyone installed one of the HKS SSQ Blow off valves? Looking at purchasing this:
http://www.ebay.com.au/itm/NEW-Atmospheric-Plumb-back-Skyline-R32-R33-R34-RB-BOLT-ON-Blow-Off-Valve-BOV-/151073396294?pt=AU_Car_Parts_Accessories&hash=item232cad1646&_uhb=1
Wondering if it's better than the others on the market?
Ssq is fnf spec
yeah ive got no idea how it runs less boost than stock
my understand, at least from skyrine was you could never run less boost than the actuator spring
no idea how this is working
but its got an eboost 2 switchable between 8psi, 13psi and then 19psi
but stock i think is 19psi
Probably actuator is adjustable/weaker spring?
EJ20s will run less boost than actuator pressure if they're in Limp mode, I don't understand how it happens even without running the factory boost solenoid but it won't let it past 4 psi. I guess it must yank shitloads of timing to keep it down?
no idea
ill have to do some reading on the evo 9 turbo and the controller setup
my understanding was from the skyline setup
where you must run the minimum spring level, you can run higher, but not lower
get one of these.
http://gfb.com.au/products/blow-off-and-diverter-valves/deceptor-pro/deceptor-pro-ii--inside-car-adjustable-adjustable-bias-venting-diverter-valve2013-08-04-02-40-32855251378-by-gfb
you can adjust from plumb back daily to fully FnF style or in between all with a switch in the cabin!!!!!
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
