last engine didn't blow because of fuel... was just everything else sort of worked together to self-implode.
Once you understand the way ethanol and petrol ignite, you will see why e85 is so much better for engine longevity. Petrol explodes quickly at the top of the piston's stroke, when the crank is at tdc. That explosion has nowhere to push the piston till the crank comes around a few more degrees. This is why the rods/bearings need to be strong, they take the entire force of the explosion.
With e85 the explosion is slower and colder, meaning less force is exerted at the top of the stroke, more when the crank is at 90 degrees, which is the point of maximum torque, and least rod/crank/bearing stress. This is partly why you gain torque with a lower energy density fuel, and entirely why my stock engine handles 40psi up the straight at Sandown. ;)
man what the f**k is this shit, im just getting him to do a quick little run in tune so i can run it in properly.
shittttt scotty, sandy vagina and shit.
sandier than aaron the niggas,
which reminds me how is that nigga, i heard he was kidnapped by these whites and sold into slavery. f**king platsys cousins.
Hmmm interdasting.
Will consider it since things are back on the drawing board at the moment.
Considering having a chat to racepace about my oil setup, i have a feeling that is playing a role in my issues. Namely flow pressure and circulation with the cooler.
yeah because springs broke, causing rockers to scratch, causing cam lobes to be damaged.
all the while bottom-end bearing fails, rod comes loose, whacks the block and scratches piston an cylinder walls.
would E85 prevented that and engine would still be running 100%? I think not.
would the tuning required for E85 continually melt my external ignition coil? possibly.
would the extra power/torque cause enough power/torque to destroy my headset? possibly.
would the 50L fuel tank need constant jerry cans on standby? probably.
Oh man :(
That was first time around I believe... Not what happened last Saturday...
Ah mis-read it!
I don't trust plant juice.
Nah, can't afford to redo entire fuel system ATM.
Trying to save for a house/ fix up mums house.
Time to invest in something
I got this fabulous scheme you can invest in
Trust me im Asian
Shuttup terrorist
lol @ redoing a fuel system to handle E85. Bigger injectors are all you need, and a fuel pump, but most people do that anyway with their 98 petrol modifications.
Have switched back to 98 a couple of times and the engine is just so much happier on E85. Not even for the power; it's the smoother more consistent idle and feeling like a brand new engine compared to petrol, which you seem to be able to feel the mileage with. Starting in super cold winter is the only time it's not happy on E, but once she cranks you're all good.
Get on it! There's a reason you've never heard someone convert to E85 and say this sucks don't do it man. Even Hatish loved it. And lol my phone auto corrects to Hatish now.
There are a few reasons not to go E85...
The need for Jerrycans is one of the major ones since not a lot of regional centres have any E85 at all, so driving to Winton or DECA will use nearly a tank, then the track day, then the drive home...
I do 300+ peak hour km's each week in my car, I could easily switch to E85 (My pump can handle it, and my injectors are 550's... might need an upsize if I want to keep some decent overhead, I pass a few petrol stations with it each day), but its still the hassle of country trips which suck.
I'll do it in the future, but for now, I'm sticking to BP98
Lol @ autocorrect.
You just can't tell some people Birds... They need to go their own way, same as everyone else, as has been done for years. What they don't tell you at school is cars started life running on ethanol, and only converted to petrol due to it being virtually free to pump from the ground. Things have since changed obviously.
So... Your tank isn't large enough? That's a great reason... :P
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
