getting quotes for new tyres for hilux so boss can make a decision... stupid tyre sizes from toyota. 205/80/16. "butter cutters" (apparently). bit pricey for what they are...
Bob Jane tried very hard to sell me 245/70/16 reckons they would fit fine on a 6" wide wheel.
Tyre Factory across the road said 245 shouldnt be chucked on a 6" wide. I dont know if he's right, but theres plenty of people driving hiluxs with stock wheels and 265 wides or bigger on them. is it because such tall profile? or because bogan?
One of the SAU VIC main sponsors is City Discount Tyres Morrabin
Got some cheap tyres over the weekend from him for the daily
Paul is your man to chat to. You may have met him at some of the track days in his Bluebird
thanks for the reminder Toby, I forgot about them. guys there have done me some solid favours. issue is boss wants it done during business hours near dandenong so no use trying to sway him on that one.
i honestly have no idea what speed im doing most of the time
is it just me or is the speedo in a weird spot?
i get revs are more important but yeah i have no idea most of the time
i dont speed a lot, but in general i have to sort look around the steering wheel to check speed
never had an issue, but did initially notice it as a bit annoying with its tiny-ness lol.
This is some serious gourmet shit! Usually, I would be happy with some Seinfeld, but go springs this serious GOURMET shit on us!
I don't need you to tell me how f**king good pulp fiction is ok? I'm the one who watched it. I know how good it is.
But you know what's on my mind right now.. it ain't the movies on go
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
