ok all sorted
the rear facing fog light switch actually turns the front ones on too - go figure
its probably like that from factory but seems odd that a rear facing fog light button turns on the front ones
they're a wierd looking light, it seems like light comes out of them but from behind the globe itself, not a direct beam, very cool :D
ok how the frig do you see the engine number on this thing
i cannot for the life of me see mine at all
there's shit everywhere in the way
will vicroads have a wah if i cant actually see it ?
like it know where it should be but its too hard to see .... ?
They might not even give 2 shits to look for it. If they do then let them look around and find it. Not your problem.
On a somewhat related note, rwc bloke couldn't find my engine number on the Subi and put another number which I'm guessing is just manufacturing related down. Glad I picked up on it else coulda been potential drama at Vicroads.
happy bday alvin?
haha also i've seen that jonoe, smh.
but it did make me want sushi. so am going to grab sushi as post-exams meal with some chums. which will probably sub-par, but will make up for it in quantity... #unilyfisthepoorlyf
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
