its better than the olympics. mainly because old people dont watch it so they dont have to make it geriatric friendly.
someone is good at shooting and quit their day job to go shoot better better than others? thats amazing.
actually there not much sponsorship for shooters, so most have a day job...
reference.
we had Commonwealth Games Gold medalist in our club..b4 she left for a good one.
reference.
girl at uni was a shooter...
yeah, still had to work part time. quite f**ked really. represent country, get paid f**kall.
a 33 4 door, 32 gtst 2 door and a integra dc2r stolen last night wtf this is getting out of hand.
not a 4 door :(
:/ people in the knox/burwood areas be very careful!
they knew that already
anyone who thinks they can make a living off shooting has some issues.
i think its only fair a commercial team gets the big dollars because then its not the AIS funding everything. the amount an olympics costs a country... its stupid really.
Honestly I'm more fearful of police than the criminals around Knox/Burwood
One gets me an insurance payout, the other makes me payout. Which is the real thief?
so much this.
might have been a different one but a silver 33 4 door got stolen as well :s and just popped up now a 32 got stolen from huntingdale station a couple of hours ago and a supra was attempted to in burwood too. :s
Surprise random work roster time!
3 days on, 3 days off, 10 days on, 4 days off, 3 days on, 5 days off. Then back to 9 days on, 5 days off.
Problem is fridge is empty & buying food for 3 days will be a write off :/
Edit: and if my maths is right, I'd be owed 2 days leave, so might make that ending 3 day swing a 1 day Perth day...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
