if you're baller enough, AD08s.
track yes, any day yes, i'm throwing out my 20km old 123's for them (thanks for that SIMON)
but for street meh
was going to keep and total them at a deca but seing that not happening, no point
I have been summoned.
They're fine for street, but as martin has said, they can run out pretty quick on the track when they get heated up too much.
For street they're great grip for the price. I just picked up a new set for $220 ea, where are you getting them for that price? Cheap Cheap... Make sure you check the age!
  • Like 1
123S? They're not semis, they should be just fine for the green monster considering its so light weight.
Though, you could go for some small AD08's if they make them that small... miniwog has been running them on his 86 for a stupid number of track days and street km's, gotta be due to the lighter weight of the car.
Actually...
http://www.achillesradial.com/en/tires/racing/achilles-123s-3
Are they even available in anything under a 17?
Normal 123 perhaps?
http://www.achillesradial.com/en/tires/racing/achilles-123-2
i need 14's and there isnt much in the way of fast street tyres. so im looking at tarmac rally and semi slick options.
just wondered how long they last....
so far only thing i have is silverstone tarmac rally in a hard.
and federal 595 in street trim.
i need 185 55 14. or wider equivalent.
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
