lol @ one of Alvin's defect reasons...
"Rear spoiler mounts are too sharp"
In case you hit a pedestrian while reversing backwards?
2. I'm not even going to reply to the color suggestion request, since it won't be one of our suggestions anyway.
1. There's only so many colours, if enough are named it will likely be one of the suggestions
2. I do hate some people who ask for opinions when they've already made their mind up...though some people wanna be assured by others they have made a good choice...I hate the ones who do it and go against what everyone has suggested
3. I was thinking of a metallic blue or dark purple which have been suggested :)
Cheers for the info re: gtst and gtr, hence my question as to how different they really are when fully set up
Which seems hard. For what its worth I wenT WOT from 0kmh with 375rwkw and had traction in first which was rather suprising. Howvever around a corner is considerably less likely.
Scotty would know how much of a stickler I am for the stealth look. If someone was just looking to buy a rb28 neo I'd sell them mine.
As for r33 colours, go get House of Kolor's Galaxy Grey. Someone did a drag r33 with this colour and it is fantastic. I asked about it for my r34 before the convo subject changed to 'prepare for write off'
I'm not buying a legit 375rwkw with traction in first unless you were running drag slicks!
Same colour. Unless you are doing bay, door jams etc, in which case MNP
Don't wanna do same colour cause to me that's always been like spending a few thousand on having it look slightly better than before. I like to justify the expense by doing a colour you can't get that model of car in, so that it's more a modification than a repair.
My current favourite contender is this, which I think is dark metallic blue running slightly into dark purple.
These things come in all sorts of custom colours, including this blue, which is quite striking but may be over the top for a non supercar?
Anyway, keep the suggestions coming and feel free to show pictures! I'm pretty open at this stage, though a blue or red or any colour that 33s don't normally come in has good odds. It would have to be a damn good silver to make me want to respray same colour.
  • Like 1
The Auto helped a lot, big semis, stock stall converter, softish rear... I drove it and was seriously impressed, especially with the auto controller. Damn shame it didn't last...
Why there was no footage of the drift day that killed my spare tyres Greg? I am quite sure it wasn't hooking up then...
Time for a c34 Stagea shell mate. You have all the good bits for it already. :P
Looks like Bayside blue to me... Decision made. :)
ahh yeah what happend with that i never got pics??
i'd go a darker shade of silver/graphite with some sort of black pearl through it....
I sent two letters back in autumn, you must notta got em? There prolly was a problem at the post office or somethin
A metallic graphite could look cool
  • Like 1
less dark and we have a weiner. good choice.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
