Who's coming to Phillip Island on the 26th for Track Day fun times?
I need a pit crew who will just smile when I blow my engine, since it'll give me an excuse to go forged and built top end... and someone to tow me home.
kthx
all this talk of Mediterranean food...booked a weekend in Malta in a fortnight, anyone been and can make suggestions?
Apparently middle-east meets italy.
The smaller island (Gozo?) is really nice apparently. Some of the waterfront scenes from Troy were filmed there. Also there is an old church that was bombed during ww2, bomb fell through the ceiling and didnt explode. Still sits there to this day.
Bus fares cost f**k all but no one can drive, but youre probably used to that.
Also eat lots of pastizzi's
kthx
Would like to, but dont think i can make it. Have fun bro. And dont blow motor. Build new one whilst old one is still running
kthx
Thinking of coming for a look see, can lend a smile if you need :P
Mate is coming back from Singapore next week.. Hoping he will deliver the cheap booze goods.
Thinkin some more Henny and some Goose
Ended up with 2x 1L of Absolut for $49
For the drinking, not the collecting obviously
I have those skull bottles...they have tequila in them I think?
Also got love for Johnny Green
R.I.P.
Yeah KAH Tequila, wanting the 750ml bottles as well there are 4 of the 750ml
Yeah that's why I got them complete set of 200ml bottles
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
