this.
flamin mongrel with "fastest micra in aus" has 148kw with 10 grand forged engine.
i have 170 with 200 dollar 300000km shit box.
ethanol man.
170 at 9psi mang, don't forget that.
When are we winding the boosts up ffs?
  • Like 1
I agree with this sometimes in the case of boredom, but now that my car is where I want it modification wise, I have no desire to modify further but still want to keep it.
Best if you can modify a car 'properly' not long after you buy it, that way if you keep it a few years you will get some good use out of the mods, and not blow your cash.
Unfortunately some workshops/owners don't know what the good mods are.
3076R Low doesn't look TOOOOO different to a stock turbo ;) Considering I'm without a heatshield at the moment anyway. Dat noise tho, pppsssssssss
Edit: Hmmmm, what do they make on E85? 330rwkw?
Buy my entire setup.
GTX 3076 will make 450kw or so on the right setup. Greg made 380 with his auto... return flow, stock airboc, 3 inch dump and intake. Stock officer. Personally I would go with the gtx71 for some extra response.
Garrett list them at 230-390kw
Go hypergear bro. Cheaper, local support and some really nice turbos on their menu lately.
i call bullshit on 450... no offense scotty.... but seriously what is that like 100psi?
Apparently 45psi, someone has done it on a SR20.
That said, was in a magazine. I was sceptical, but given I got 405 on 28ish psi, I see no reason that 15 extra psi wouldn't result in 50kw...
Inb4 stao
Inb4 toby's 400kw
HG turbo checking in, 15,000km and spinning like the day it was put in
I'm not saying they don't work but really they are not very much if at all cheaper than Garretts and due to having a plain bearing core you do lose some response(and that cool whirr down noise after the cars turned off :P) I just don't see them as excellent value for money.
hiflows are. other than that? no.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
