dirt bikes are for bogans who like ruining forests and destroying silence for kms around.
i'd rather support hunters/shooters who actually enjoy the outdoors.
save your coin. for someone who lives at home, you sure do have a lot of space to put your toys.
That's rough man :( :(
I see your lengthy weapon and raise you pyjamas no self disrespecting hipster could ever cut through
2012-autumn-and-winter-new-men-and-women
I will cut around it so you bleed out slowly and painfully. you now have the added insult to your family of your corpse looking like a douchebag
I'm not saying they don't work but really they are not very much if at all cheaper than Garretts and due to having a plain bearing core you do lose some response(and that cool whirr down noise after the cars turned off :P) I just don't see them as excellent value for money.
Recon your $2500 500HP Garrett can beat one of mine $2500 500HP SS-Alpha in response? :rolleyes:
And Ball what bearing?
I choice to not to for good reasons.
you should always take into consideration the HELP/HECS repayment based upon your HRI dude
At least then you will know exactly what your tax position is
I can always dream can't i?!
Bro tip to self: buy more negatively geared properties
I'd blind you with a camera flash and given Apple doesn't support flash you'd be fresh out of luck
It's more of a joke to defend Flash these days :P Android doesn't support Flash either, it's a dead application.
Turbo looks good, but unfortunately its Chequered, so it's more like 350rwkw not 435 lolololol pls.
  • Like 1
You do realise that Trent uses a correction mode that gives basically the same results as a dyno dynamics... Only more accurate...
Just cos he does a better job than your mob for half the cash is no reason to hate :P
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
