Whats the retail on one of those? *inb4 more than you can afford pal*
Need to finance it against my mortgage
According to a article, you might just have to sell your taxi, bikes, brothers stuff without him knowing to be able to afford one with finance.
Simon if you can ever find brake pads for that kit I'd love to know, as I have the same Kit and Just Jap have no idea which pads actually fit it
which was fantastic
Richo runs them, so I'll get some advice from him... I guess the best thing would be to find out which car (if any) has compatible pads so I can quote that car when i'm searching for them.
They'll come with a set of pads, so I'll be taking some measurements and pics of them before they go in so I can be sure of what to get in the future :)
The QFM A1RM's performed really well all through the day, didn't let me down once... until they disintegrated.
HEL braided lines just arrived for the front, rears and clutch (dunno if they'll mate up to the new front calipers though), just gotta grab some decent fluid now and wait until I'll be able to install them :)
Want some motul brake fluid I won at sau dyno day? lol
Depends... do you know which one it is?
https://www.motul.com/au/en/products/oils-lubricants?f%5Bapplication%5D=144&f%5Brange%5D=25
The CP5070D54 sized pads fit. Most manufactures make these.
You can get them in DS2500/3000, HC800/Club Racer, Blue (DP5006)/Orange (DP9006) Stuff.
I really liked the project-mu, but it was costing too much. So used the Blue, then went to the Orange when I stopped driving it on the road.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
