Went to switch for dinner last night, ordered the eye fillet rare - dat mofo was brown as anything and chewy as f**k. do not rate /10.
Hamish I'm pretty sure if that was you.. would of walked out lol seriously, that bad. It was so chewy, that by the time I got to my veggies they were completely cold.
  • Like 1
need to update the app then its all good
Apple update says all apps all up to date ??
Im the only one with all my teeth at the pub and cant get the young(ish) girl at the local pub. Disappoint
Did not die... I earthed the casing properly and they wired up easily enough...
1 x 500w halogen which gets hot as all hell and burns through a globe every few months
vs
1 x 30w LED.... I will be installing 5 of them around the roof of the garage (you can see 1/3 of the garage space in this pic), the driver and the globe area don't even get warm after being on for an hour, so thats good enough for me :D Still waiting on a reply from the ebay seller after I called him out on his bullshit CE stamps...
too drunk to askd pub waitress out... find out shes still in high school *awkward*
ill just go back to my room and feel bad for myself and others. depressing night is depression,
Mate get back in there and invite her back... She could be above year 10...
  • Like 1
i have never seen that... lol
wait... you eat your food in component order?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
