43 Megapixels? uwotm8? They threw that number into the keynote to get some wow-factor... however they were referring to how large a panorama image can be now... It's actually 8mp, but with a really good sensor and lenses.
Adam is on ethanol. No f**ks given for EPa so long as its not loud?!
Either way a stock exhaust for the day will be fine man.
Illegal to modify ecu or fuel setup in vic. So I cant see many cars where e85 could be legal in 90's cars
fixed for accuracy.
He actually does ask me that every morning and it does piss me off... As well as 'get up to much last night'?
I couldn't look any less interested if I tried, yet still he asks me the same shit every day
Hi Michael how are you?
nistune is undetectable, and your fuel pump went so you replaced it, and you run ethanol cos its cheaper.
shit switch on man.
but yes, a nistune setup is the least detectable around. also need to remember to paint the injectors stock colour
also, birds would have so many issues with your for sale ad dude. not once did you quote a reachable power figure, but twice!
also, glws.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
