Is there anything other than a hipster burger joint in Melbourne?
Damn near went on a beard shaving massacre when I saw a f**king taco truck.
Stick to coffee you f**king beta f**ks.
  • Like 4
on way home from cocktails and tapas from Bluestone restaurant. goddamn tasty.
still recovering from the chorizo. so much fat but so tasty.
hipsters don't do cocktails. too pricey and experimental
  • Like 1
Hahaha, so awesome :D
You couldn't be more wrong.
Hipsters loooove themselves an experimental cocktail, from a bar with a lame name like "Naked for Satan"
Not really. All of the good burger joints are at least 73% hipster.
Ordered 2 burgers down at the beach yesterday..
2 with the lot one with no pineapple...
Stupid bitch put pineaple on both and missus has allergic reaction, was quite funny to watch.
but not funny. :angry:
Thought about complaining but I ate the evidence...
What's the correct procedure for complaints Joe...you'd know?
Fallen off my burger tour... 2 of the boys at work rate 8 bit highly... and others seem to be saying Huxta is no good, was decent the first time I had it, but not so much the second time... I'm thinking they've dropped off the quality with the increase in business...
"They used to be good before they went mainstream" #hipsterdezz :P
Royale Burger is killing it at the moment.
And I have heard nothing but bad reviews of 8 bit lately.
Once you are super popular it's very hard to keep the quality there.
We had a blackmores wagyu burger today at Burhnam Beeches. Awesome place. Will go again for sure!
You been casually conversing with people at work? What a delight that must be
One of the 2 that sit across from me is fine, he's a mate...I think my dislike for the other makes me hate everything he says, but, hatred aside, he does say some really stupid/pointless shit, and in a real mother f**king annoying way.
"Am I wrong? Am I wrong?"
"Is that fair to say? Is that fair to say?"
Etc.
Etc.
Give him a knuckle sandwich Monica
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
