Is there anything other than a hipster burger joint in Melbourne?
Damn near went on a beard shaving massacre when I saw a f**king taco truck.
Stick to coffee you f**king beta f**ks.
  • Like 4
on way home from cocktails and tapas from Bluestone restaurant. goddamn tasty.
still recovering from the chorizo. so much fat but so tasty.
hipsters don't do cocktails. too pricey and experimental
  • Like 1
Hahaha, so awesome :D
You couldn't be more wrong.
Hipsters loooove themselves an experimental cocktail, from a bar with a lame name like "Naked for Satan"
Not really. All of the good burger joints are at least 73% hipster.
Ordered 2 burgers down at the beach yesterday..
2 with the lot one with no pineapple...
Stupid bitch put pineaple on both and missus has allergic reaction, was quite funny to watch.
but not funny. :angry:
Thought about complaining but I ate the evidence...
What's the correct procedure for complaints Joe...you'd know?
Fallen off my burger tour... 2 of the boys at work rate 8 bit highly... and others seem to be saying Huxta is no good, was decent the first time I had it, but not so much the second time... I'm thinking they've dropped off the quality with the increase in business...
"They used to be good before they went mainstream" #hipsterdezz :P
Royale Burger is killing it at the moment.
And I have heard nothing but bad reviews of 8 bit lately.
Once you are super popular it's very hard to keep the quality there.
We had a blackmores wagyu burger today at Burhnam Beeches. Awesome place. Will go again for sure!
You been casually conversing with people at work? What a delight that must be
One of the 2 that sit across from me is fine, he's a mate...I think my dislike for the other makes me hate everything he says, but, hatred aside, he does say some really stupid/pointless shit, and in a real mother f**king annoying way.
"Am I wrong? Am I wrong?"
"Is that fair to say? Is that fair to say?"
Etc.
Etc.
Give him a knuckle sandwich Monica
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
