When I had huge new NT05s 2nd was half decent, once they got a bit worn a old skate sesh.
Now I'm rocking dunlop 245s pretty good, holds 1st and 2nd brah. such grip. wow.
Edited by UNR33L
Depends what tyres you have I reckon. My setup was only just holding second when the tyres were new...I'd like to be able to put foot flat to the floor and not have to pull back on boost cause of wheelspin. 300 on E85 would be semi slicks and still break it in 2nd I reckon.
you run KU31's don't you...
I had traction through with 320rwkw and NT05's
On the front
Got R1R Proxes on the rear
Prolly not as good in the dry as NT05s but I bought them as a wet compromise cause NT05s are deadly in the wet lol
How big were your NT05s?
so much learning to modulate throttle needed.
do some track days and learn to drive it properly.
None of this street hero business.
speaking of business
Qantas Bushiness upgrade for tonights flight to Dubai..nice.
  • Like 1
Try the evo in the wet.
235 kinforests (im not even kidding) and you can launch it in the wet with traction through all gears lol
Granted is only 175kw atm but still it's spastic
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
