Vic Wasteland Thread
R31Nismoid
Dammit, first accident ever. Luckily it was only minor. Hit the back of my friends motorbike at a roundabout, thought he was ready to go as it was relatively clear and he stopped, ended up hitting the back. His bike is basically undamaged, but it looks like I need a new front bumper.
The good news is I was going to change my front bumper next year, so I guess it's just an early upgrade. Do I need to get a Series 1 Reo for most front bumpers? I don't want to go Series 2 again. Also, can someone link me to a decently priced aftermarket bumper? I love the GTR look but from what I've seen I'll also need to change the bonnet and quarter panels.
The good news is that its just the front bumper, the better news is that your mate it ok after getting hit by 1.5 tonne of metal :P
Well that's true haha. Luckily it was only at a few km/h, and not something more serious.
I think I've also decided on the Top Secret bar as well, seems to be the closest to the GTR while not costing an arm and leg.
My car was broken into on Saturday night. Doesn't help the I left the keys in the ignition on Saturday and forgot them in there overnight.
The only taken was about $20 in coins from the centre console. I consider myself lucky.
i cant believe i missed this thread: http://www.sau.com.au/forums/topic/447336-nrma-vintage-and-classic-insurance/page-5
I might give http://enthusiast.com.au/, http://www.racv.com.au/wps/wcm/connect/racv/Internet/Primary/insurance/car+insurance/veteran,+vintage+_+classic and http://www.lsvinsurance.com.au/ a call... see if they'll do the pulsar (16 years old wew) or consider a personal import a classic if under 15 years...
What you need is the headlight supports. (the black bits). The reo bar, the actual big massive metal bit in the middle is the same part for series 1 and 2. The headlight supports are different. A lot of people refer to the headlight supports as "the reo bar" or part of the whole assembly, so the whole "is it the same or different" can both be answered with "Yes" depending on who you ask.
(and of course I have a front bar and reo for sale but its all series 2 ;))
Guest
    • @Butters I can't tell you why but the bigger HKS step 2 cams improved low and mid end immensely. Turbos started spooling about 1k RPM less than before and the idle/vacuum was rock solid, it was an absolute thrill to drive, 3rd gear pulls hit 180kmh where previously only managed 160. Conversely, the milder poncoms in there now have a funky idle making it harder to get off the line, drives poorly in lower revs, laggy and makes less power/torque throughout. Feels better after I swapped the EBC but unless I put it on the Dyno again, I can't say how much better.
    • Hi Sydney kid   do you still selling spring and blistein shocks for Nissan 260rs? Air any suspension upgrades? Please advice     yudy
    • Cams are not needed at this power level, they will create lag. The cam gears are a good idea though.
    • @Murray_Calavera yeah, I guessed as much, cooler temps, more boost, less knock, more timing, hello power. Unfortunately not quite within reach ATM, could upgrade my whole fuel system to support but still wouldn't have E85 to run it 😂  Anyway, I changed cams again, 260/260 poncam B and everything else the same except an EBC upgrade. Now I must say I was quite disappointed with the result as it was like running stock cams (didn't try to dial them in as they're supposed to be optimum already) but after awhile I suspected my new EBC was underperforming not to mention difficult to use. I recently swapped back my old EBC and it drives much better now, boost comes on sooner, more stable, no spikes etc, feels all quicker and faster than with stock cams. Planning to fiddle with the cam gears and see what happens but maybe skip the Dyno as I intend to revert to the HKS cams cos they really made the car come alive; low and mid end was unbelievable and it just wanted to rev to the moon, finally knew what people were raving about, RB26 really loves revs. Anyway, Dyno 03 is quite disappointing, in Dyno 02 although peak power was less and trailed off at the top, the low and mid end improvement more than made up for it.
    • @Darrel It's so tempting to say e85 is borderline magic. It cools the intake charge, so if you're flirting with the edge of the turbos compressor map it helps dramatically cool down the hot air the turbos are pumping. It is very resistant to detonation so you can crank the timing, I don't really want to say you won't be knock limited anymore.... but you probably wont be knock limited anymore lol. I wouldn't be surprised if you made 20% more power swapping to e85 (provided you have the fuel system to support them, bigger injectors maybe bigger pump etc).
