Most of the places I do cash jobs with give an invoice.
it's more they not paying for transaction/paypal/whatever fees
and also have the money there and then not in a few days times when the bank feels like it. (but that usualy when doing goods)
that said when just paying for services, cash jobs whole diff matter..
Not before you question the mark-ups these mahf**kers are putting on their shoes, in the knowledge that people will queue for days to get them ;)
Rich game, no f**ks given.
Half our retail though it's based in U.S / Canada so probably normal for them.. Some of the shoes are pricey I haven't bought on there but Googled em feedback was all pretty positive
Yeah I meant cheap for US...Even US sites airmax go for $130 ish, unless on clearout/sale/old as f**k models.
They don't have the ones want anyway so yeah
When I do cash jobs, it's to avoid paying tax
I plan to build a wagon like that one day. I've had a few turbo falcons, one of them was a EF fairmont with a little TO4E on it. It was manual and made full boost by about 2500rpm. 250kw of external gate goodness.
+ 1
If you need assistance send me a PM and i'll see if a cash job can be done
I need an unconventional engine rebuilt. Any help welcome... esp if the shop is in Clayton.
what unconventional? rotary?
3 cylinder 1L daihatsu engine :D
It's got no compression on one cylinder. Bought it as parts car for my gf's Cuore, but it's actually in better nick than the one she's got, so rather than pilfering it for parts, if I can get the engine redone cheap and put it back on the road, I can flog her existing Cuore off and keep the parts car.
I can engine out myself.
Well he builds all sorts of engines
He probably rebuilds an engine a day, not just high performance, lots of insurance ones. So i'd say he's dealt with a wide variety
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
