Such a nice day!
MIght take the Evo for a dri.....
oh
At least the money in your pocket beats this scenario
"Such a nice day, might take the Skyline for a dr..."
"I'm onto my 5th engine in 25,000kms in the course of 7 years"
Evo spent the whole weekend up on stands.
Also, snapped 2 rusted bolts off.
Also, snapped an easy-out after drilling into said bolt.
Also, painted some stuffs and repaired some other stuffs.
Happy times.
Need a new laptop...
Has to be fast, as I have an extremely short fuse for slow computers... Decent sized screen, 17"... Will pretty much be used as a desktop so not to worried about the size/weight..
Partial to Asus.
Want the lambo one but I don't think they've got a new model of it which has the same specs as their other latest laptops...
Tech geeks, go.
yeah larger is a bad sign
the point of the lemon is to mask the off smell it corona is bottle fermented so has a yeasty small, the lemon hides that...
if it the same beer it could be a culture thing, or a more ulterior motive.
nope.
lemon is to keep flys away from bottle.
I'd probably go something like this:
http://www.scorptec.com.au/product/Notebooks/Gaming_Notebooks/54133-GE70_2PE-038AU
Depends on your budget though really, a lot of the cheaper 17" laptops don't have SSDs in them I've noticed.. which ofcourse you're going to want if you hate waiting around for stuff.
i think he was being serious fella.
Then he should buy a Macbook. Anyone with proper knowledge about computers knows they are actually the best overall laptops on the market.
Besides the screen size, what else do you need from the laptop?
  • Like 1
Maybe he doesn't want Mac though?
shockhorror!
how very dare you suggest using a computer you cant do f**k all on? apart from write a screen play in a fairtrade coffee joint, before you go home and masturbate over the baristas beard.
  • Like 1
loled
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
