Such a nice day!
MIght take the Evo for a dri.....
oh
At least the money in your pocket beats this scenario
"Such a nice day, might take the Skyline for a dr..."
"I'm onto my 5th engine in 25,000kms in the course of 7 years"
Evo spent the whole weekend up on stands.
Also, snapped 2 rusted bolts off.
Also, snapped an easy-out after drilling into said bolt.
Also, painted some stuffs and repaired some other stuffs.
Happy times.
Need a new laptop...
Has to be fast, as I have an extremely short fuse for slow computers... Decent sized screen, 17"... Will pretty much be used as a desktop so not to worried about the size/weight..
Partial to Asus.
Want the lambo one but I don't think they've got a new model of it which has the same specs as their other latest laptops...
Tech geeks, go.
yeah larger is a bad sign
the point of the lemon is to mask the off smell it corona is bottle fermented so has a yeasty small, the lemon hides that...
if it the same beer it could be a culture thing, or a more ulterior motive.
nope.
lemon is to keep flys away from bottle.
I'd probably go something like this:
http://www.scorptec.com.au/product/Notebooks/Gaming_Notebooks/54133-GE70_2PE-038AU
Depends on your budget though really, a lot of the cheaper 17" laptops don't have SSDs in them I've noticed.. which ofcourse you're going to want if you hate waiting around for stuff.
i think he was being serious fella.
Then he should buy a Macbook. Anyone with proper knowledge about computers knows they are actually the best overall laptops on the market.
Besides the screen size, what else do you need from the laptop?
  • Like 1
Maybe he doesn't want Mac though?
shockhorror!
how very dare you suggest using a computer you cant do f**k all on? apart from write a screen play in a fairtrade coffee joint, before you go home and masturbate over the baristas beard.
  • Like 1
loled
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
