what's the actual name of the wireless adapter? like if you go into device manager > network adapters, i'd start by getting the name of it and googling to see if anyone else has had the same issue.
I had a problem with my wired ethernet recently.. one particular driver version wouldn't let me run an online application and was a known issue after a quick google.
well the networking stack and such is fine as it works on ethernet, so odds are a drivers issue.
when connected to Ethernet, go into device manager delete the wifi drivers.
go to the manufacture site and download current one.
install
hope for best.
(I am assuming you have rebooted......)
damn feels like I'm bigpond support again..
Kunce got a speeding fine after they took my car. Not sure if I want to look at the photo or not to see their f**kin ugly mugs in my baby
How quick and what location?
Also yes, obtain and post photo.
  • Like 1
AC 7260
I googled it while trying to fix it and it's obviously a VERY common problem to the point where msi are literally robbing people for the money they're charging for it.
How can a f**king high end gaming laptop have such bad wifi
The thing is f**kin useless to me now
70 in a 60 zone.
Preston of course, directly on the way from Hawthorn to Mill Park
Mill park is where that dude had the white s2 part's with new headlights, did you look into him?
That was Lilydale or Kilsyth or some shit. Didn't bother.
Dezz, you free next week Monica? Could belt the kunce over the head with your new laptop
Edited by HEKT1K
  • Like 1
yeh, the dude lived in kylsyth but in the background of one of the photo's there was a deleted add that had the items advertised as being in mill park. (he took a screen grab)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
