VQ30 neads moar stainless intake and exhaust.
also needs some tint.
and some coilovers. and some low.
then its waiting game for wheels and body kit.
christmas presents for family? pfft. getting a ride in the car is generous enough :P
I removed the tint from the skyline after it came back from an insurance repair horribly scratched and tearing... Didn't really miss it too much since it was horrid blue jdm tint which was turning blurry.
Now I'm in the Emo with tint darker than Ric with a tan, I love it again... Coming into Summer it's gonna be gooooood. Reduces glare from headlights etc as well, sun in the mirrors, etc
Is it legal? Probably not. :/
Edit: No Mike, Bronze tint is aids
I reckon they should polarise front windscreens... Headlights are a PITA when in a low car. And sunrise/sunset are also annoying.
Some renaults come with that blue-tinge windscreen... Wonder what that is.
Yeh, prev owner said it was darkest legal, but I have my doubts lol
inb4 granny spec
GAAAAAAAY
Eww not like that, moar liek dis
GAY
thinking this would suit more:
GAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAY
or go Filipino style
tint the front as well
LOL
How dark is 15%? Can you stand outside and see see inside?
Nevermind, found comparison photo.
hmm... 15% or 30%, can't decide.
35% is legal darkest. even then it's not really super easy to see stuff inside the car.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
