3" fujitsubo legalis.
im wrapt with the power though.
My 3inch wasn't even a 1kw restriction when we tested at 320-330rwkw on 98 octane.
And wasn't a restirction at 380rwkw on E85
Just sayin
  • Like 1
Not all 3 inches are created equally
Moh are you running a cat...if so, ditch that...
Cooler piping and cooler is always an obvious one
Intake pipe sucking shut is never good
Sometimes the turbo you've chosen can have a restrictive exhaust housing particularly if it's a responsive turbo and gets choked up top
That power is plenty for the street, hit up E85 and be laughing
i do have a decat.
ill throw some intercooler hardpipes on this bitch when i can.
wouldnt be intake pipes, george is making about 400kw with stock intake pipes and cooler.
my problem is i dont want a cannon, and all the free flowing exhausts are cannons.
also will need cam gears, and may go for a set of cams while im there. because mohsen.
but most importantly, ill have to drive it for a bit and get used to it.
Don't understand why workshops if they say its an exhaust issue, just don't quickly test it by dropping the exhaust. (As long as the customer is happy to pay for the extra time)
Would suck for Moh and other customers if they bought a whole new exhaust system only to come back and have the exact same issues
i do have a decat.
You have 707160 -9s yeah?
Should make 300+ at 18 especially with rebuilt motor.
they didnt say it was exhaust, not sure whats up. the car has been an absolute bucket of shit.
my first build experience has been nothing but a nightmare.
just random shit that shouldnt have happened. eg: f**king vac leaks everywhere.
You did replace every vacuum hose on the engine while it was out though? Right?
Generally Fujitsubos have a narrowed down part of the piping just before the rear muffler to keep things quite despite being a 3" system, even their cannon systems have this
Also 2nd spot of the new falcon today (first on saturday night at ribs & burgers in Cragieburn)
Digging the bronze colour much more than the blue, looks more like a BA/BF shape again though
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
