3" fujitsubo legalis.
im wrapt with the power though.
My 3inch wasn't even a 1kw restriction when we tested at 320-330rwkw on 98 octane.
And wasn't a restirction at 380rwkw on E85
Just sayin
  • Like 1
Not all 3 inches are created equally
Moh are you running a cat...if so, ditch that...
Cooler piping and cooler is always an obvious one
Intake pipe sucking shut is never good
Sometimes the turbo you've chosen can have a restrictive exhaust housing particularly if it's a responsive turbo and gets choked up top
That power is plenty for the street, hit up E85 and be laughing
i do have a decat.
ill throw some intercooler hardpipes on this bitch when i can.
wouldnt be intake pipes, george is making about 400kw with stock intake pipes and cooler.
my problem is i dont want a cannon, and all the free flowing exhausts are cannons.
also will need cam gears, and may go for a set of cams while im there. because mohsen.
but most importantly, ill have to drive it for a bit and get used to it.
Don't understand why workshops if they say its an exhaust issue, just don't quickly test it by dropping the exhaust. (As long as the customer is happy to pay for the extra time)
Would suck for Moh and other customers if they bought a whole new exhaust system only to come back and have the exact same issues
i do have a decat.
You have 707160 -9s yeah?
Should make 300+ at 18 especially with rebuilt motor.
they didnt say it was exhaust, not sure whats up. the car has been an absolute bucket of shit.
my first build experience has been nothing but a nightmare.
just random shit that shouldnt have happened. eg: f**king vac leaks everywhere.
You did replace every vacuum hose on the engine while it was out though? Right?
Generally Fujitsubos have a narrowed down part of the piping just before the rear muffler to keep things quite despite being a 3" system, even their cannon systems have this
Also 2nd spot of the new falcon today (first on saturday night at ribs & burgers in Cragieburn)
Digging the bronze colour much more than the blue, looks more like a BA/BF shape again though
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
