Apart from the seats the interior is probably as good as your r32
The e3 was slightly better but for a 80k car it's laughable
for what it is and what theyre going for at the moment, good bang for buck. considering ill probably get bored of it and sell it in 3 or 4 months. lol
for what it is and what theyre going for at the moment, good bang for buck. considering ill probably get bored of it and destroy it in 3 or 4 months. lol
fypformohsen
Awesome Telstra
Sent me a bill for $2...wait for it...to cover the paper charge for sending me a bill for $2
Are automatic systems supposed to make life easier? Because it seems to me they just f**k everything over for most part
so guy at work,
has a S15 and was getting some work done
repaint stereo alarm and a few other little things.
Decides to put some new rims on it.
goes out, buys a set of super advans
had them stripped cleaned up and powder coated.
so they finally finished and ready to go on the car.
finds a pic online of a S15 on super advans...and first comment was, oh shit that looks crap...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
