Munich Brauhaus
Fk me this is where all the hipsters end up on a Friday night
Everyone looking at me because I don't have an ironic beard or a flannel shirt and boat shoes, fark off you trendy dick holes
  • Like 2
Munich Brauhaus
I was just there an hour ago, I had a fun time with my friends instead of pissing and moaning about what other men were wearing
  • Like 3
You must have been wearing flannel
f**k I hate those cock suckers, they all want to be 'different' yet all look EXACTLY the same.
Cock suckers.
Yeah can spot em anywhere and everywhere, it's the most common fashion these days so dunno what they're going for, or what women are into it for that matter
Negative battery terminal was a little loose... could wiggle it a bit by hand...
After the wiggle, drove nearly an hour to get home and it didn't fk up once, cleaned up the terminals, tapped it all the way down, tightened it up... good to go :)
Weird head unit lost my preset stations and time, yet kept settings for bluetooth sync to my phone... :/
  • Like 1
Lol I have the Bose qc20i noise cancelling headphones. Epic sound clarity and noise cancelling for an in-ear headphone.
Yeah but built in battery,
they claim 16 hours lay so expect 12, and a Europe trip 20+ hours.
thus why I skipped on Bose.
I can get around 20 hours off a AAA in mine, plus when flat it just a quick swap away from back in action.
bose noise canceling is a little better than Sennheiser however,
Different kinds of headphones excel at cancelling different kinds of noise...
One might get rocking reviews, because its been tested in an office, street and shopping centre... But it might be useless on planes because of droning frequencies coming from the engine on the wing right next to your seat.
Munich Brauhaus
Had a work thing there last Friday. Drove into the city, took one look inside this place, turned around and left for the same reason.
  • Like 1
It wasn't bad after it quietened down...huge claustrophobic crowds just exacerbate my dislike for people's idiosyncrasies and severely lower tolerance for society on the whole. I really hate crowds and queues, especially at festivals. Really nice beer. Staff not speaking a lick of English is retarded, like a hire backpackers only policy...I guess it's trendy these days to order from someone with a language barrier.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
