Munich Brauhaus
Fk me this is where all the hipsters end up on a Friday night
Everyone looking at me because I don't have an ironic beard or a flannel shirt and boat shoes, fark off you trendy dick holes
  • Like 2
Munich Brauhaus
I was just there an hour ago, I had a fun time with my friends instead of pissing and moaning about what other men were wearing
  • Like 3
You must have been wearing flannel
f**k I hate those cock suckers, they all want to be 'different' yet all look EXACTLY the same.
Cock suckers.
Yeah can spot em anywhere and everywhere, it's the most common fashion these days so dunno what they're going for, or what women are into it for that matter
Negative battery terminal was a little loose... could wiggle it a bit by hand...
After the wiggle, drove nearly an hour to get home and it didn't fk up once, cleaned up the terminals, tapped it all the way down, tightened it up... good to go :)
Weird head unit lost my preset stations and time, yet kept settings for bluetooth sync to my phone... :/
  • Like 1
Lol I have the Bose qc20i noise cancelling headphones. Epic sound clarity and noise cancelling for an in-ear headphone.
Yeah but built in battery,
they claim 16 hours lay so expect 12, and a Europe trip 20+ hours.
thus why I skipped on Bose.
I can get around 20 hours off a AAA in mine, plus when flat it just a quick swap away from back in action.
bose noise canceling is a little better than Sennheiser however,
Different kinds of headphones excel at cancelling different kinds of noise...
One might get rocking reviews, because its been tested in an office, street and shopping centre... But it might be useless on planes because of droning frequencies coming from the engine on the wing right next to your seat.
Munich Brauhaus
Had a work thing there last Friday. Drove into the city, took one look inside this place, turned around and left for the same reason.
  • Like 1
It wasn't bad after it quietened down...huge claustrophobic crowds just exacerbate my dislike for people's idiosyncrasies and severely lower tolerance for society on the whole. I really hate crowds and queues, especially at festivals. Really nice beer. Staff not speaking a lick of English is retarded, like a hire backpackers only policy...I guess it's trendy these days to order from someone with a language barrier.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
