I think the proximity to Channel 7, Premiers Office, Reserve Bank, Westpac and Commbank Headquarters and the US Embassy would have also been a factor in the choice of location.
  • Like 2
Thank god you explained the reference
This. Leigh I require your services this coming weekend; I am attending the screening of a new satirical/parody movie and would like you to explain the pop culture references for me.
As per usual, you'll need to pay for my services
nohomo
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
