I've never had a steak go cold on me, apart from the 1kg challenge I did...
What if you're no good at cooking steak...?
And if you go to a good steak restaurant /good restaurant in general, your steak will be juicy
Well true it doesn't go cold, but a normal steak doesn't stay anywhere as hot as stone grill. It's like that first awesome bite of steak, but over and over again. Old man travels across town just for it haha
Ain't really cooking it yourself anyway, cause it cooks quick enough that you're pretty much just cutting pieces from the block as they cook; it's hard to screw up unless you're a real slow eater, but can always pull steak off the stone I guess.
Haven't even taken delivery.... just signed contract.. should have it in a week.
it's not exactly a 300rwkw R33... but it is far more convenient for driving kids around which now make up some 99.27% of my driving
lol @ single mum.
is $160 fair price for A/C re-gas? (from scratch, not top-up)
bit tasty, but its summer so 30% increase.
check out cranbourne auto elec. ihe was a top bloke, charged me 180 for a service, few orings, labour for repair and gas on wrx.
Tony have you got the dyno read out from your 380rwkw with a 3" exhaust? Boss has told me in the past that it's almost impossible to see over 330kw with a 3" exhaust.
Yeah it was on Trents dyno, did a drop of the exhaust and no restriction
Its a jjr 3 inch dump and cat, then get slightly bigger to the muffler
Refitting for that new style refrigerant as well?
Y34 should already be R134a, even 33's are already. 32 etc need to be converted from R12 doe.
AC in the new RS is f**king awesome. Have receipts for regass done in 97 and then again in 2011. On the way back home from shitney had to keep turning it off cus it was too cold.
  • Like 1
  • Like 1
aye is pvc pipe okay? Ill use the proper plumbers cement.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
