so few few MS events announced.
PI on 8th is first up..
plus a new deca type event....mmmmm...been looking forward to this for a bit.
few more surprises later in year
Yep, deca just down the road from us!
PI on 8th of Feb? What's this.. Am I entering WRX PI day or not! :P
how is having Lenso 20" and NEXEN rubber a sales point?
Also love how nearly every car is a lady driver, but with a male name selling it
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-3156017&Cr=4
Wouldn't buy a legitimate lady driven car anyway - most don't look after them mechanically or have little mechanical sympathy or the ability to perceive mechanical faults.
Might have to come to this motorkhana day hmmm
Just need to get a race suit and driving gloves
that's just for the drive there right?
remember one of my mates turning up to winton in his R32 GTR
factory seats and everything, but arrived with full harness on and race gloves on..
3 years later and still not lived it down.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
