Buy Investment property.
Then buy another one.
Buy jetski.
Have so much f**kin money that you have to retire at 40.
Thats what everyone else in aus is doing, right?
Every Joe Shmoe wanting to own an investment prop. The quality of houses going up today is purely driven by lowest build price for maximum rental return.
Sale Prices aren't relative either as rental income always a factor.
/1st home buyer problems
  • Like 1
+1
For the last 10-15 years basic houses in Melb have been fkn terrible quality that will show in 5-10 years, all those kit homes and duplicates/clones in the western suburbs especially.
  • Like 1
My to-do list before I go back to work next Wednesday is small, but not at all decreasing. Procrastination is stong
Buy dishwasher
install headunit in excel
track day saturday
track day tuesday
The last 2 of those will get done, but that's probably about it
Anyone know a towie in east / south east who is good with lowered cars / does cheap or cash jobs?
Jack from Citywide towing on 0419877437
towed most of the SAu motorsport ppl at some point, plus grant a couple times.
used to do a bunch of track days in his 33 gtr so he know how to get them on and off the tray.
only issue is when he tries to buy the car off you, eh grant....
Sounds like my man
Ta
Gonna see what the limits are with them... who knows, turbo could max out first...
No point going and spending a grand on injectors and rail if what I've got is fine.
i was gonna go e85 on my 550's for the wrx, but i feels there is not enough duty left in em.
last thing you want is sitting at 95% +.....
you have adj fpr just to give em a bump?
Was at 278rwkw (racepace) on 98, I think approx 70% duty after pulled back to safe track tune...
Here's hoping for a safe tune that I can run with for more than 1 track day without popping something again.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
